Technical Disable Skyroof. (Deckchair, HELP!)
Anyone with a Skyroof now has a way of isolating it if they want to use original FIAT roof bars. (y)
Looks like a nice job but maybe I'm missing something here since with the 5 door you can open the Skyroof with all sorts of loads.
I've had bikes on the top and even a bed without issue but you do have to watch for any straps which may be hanging down :eek:
Is the load area lower on the MW or something :confused:
It depends on the roof rails and the roof bars you choose to use, plus how and what you attach to them. I've chosen to use original Fiat rails and bars and because of their low profile somethings like my Mount Blanc bike racks can stop the Skyroof opening fully. My Roof Box has strenghtening ribs on its bottom that protrude even lower so its more of a problem.
I didn't have a Skyroof in our old 5 door so I'm unsure of the clearence difference when using Fiat rails and bars. I used Thule universl bars on our 5 door and thinking back there did seem to be more clearance but I not 100% sure.
Hi all! I have poor english...I have problem whith skyroof on my Stilo 1.6 3dr 2004. Rattle last section of skyroof,but when i open it for 1-5cm all is OK.May be somebody now how solve this problem.Wait for you answer!Thnx.
Опишите вашу проблему в вашем родном языке (русском). Я перевожу на английский и помочь вам.
Проблема следующая. Когда едешь по ровной дороге все хорошо, но когда дорога плохая, то от люка доносятся удары. Удары в задней части люка. Это не скрипы, а именно удары!
"удары в задней части люка"
Небо крова може се ресетовати притиском на дугме за контролу 10 секунди. Чућете Небо крову ресетовање себе. Ово може излечити проблем.
In English please. I don't understand
My Russian is no good ... :eek:
Russian
English
It does not creak, and it blows!
Blows. Do you mean:
Impact?
or
Movement of air?
If you mean "impact" is it something loose making a noise when on rough roads?
If you mean "movement of air" are you saying air makes a noise as it some how passes the seals of the Skyroof? This can be cured by resetting the Skyroof, just press and hold in the control knob for about 10 seconds.
Yes! impact is it something loose making a noise when on rough roads!
just press and hold in the control knob for about 10 seconds - did not help.
I believe in a mechanical malfunction.
