Generally speaking, a holesaw would be the best tool (Think of it as a "cirular hacksaw) :-Question.
Has anyone cut a hole on their dash? Whats the best way to cut the hole I need to insert the switch?
[ame="http://en.wikipedia.org/wiki/Hole_saw"]Hole saw - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File
You can usually pickup a reasonable [sub-£5] Multi-size adjustable one from many Tool/Car-Accessory shops, etc which will work fine on most dashboard plastics (or LIGHT "backing metalwork"_ ...
... However, IF the spot where you wish to drill has a SUBSTANTIAL metal inner-backing, you would probably need a better quality hardened-tip type (like a hacksaw-for-steel) to cut through ... OR alternatively, draw a circle where you want the hole, then drill a series of adjoining-small-holes around the circumference with a small drill bit, then use a dremel to join those holes & clean up the edges.
EDIT :- Forgot to state the obvious ... Don't forget to ensure there are NO wires, etc BEHIND the area you are cutting into.
Personally, as you are intending to use that airbag type switch as a simple on/off (non-lock) mode ... I would have suggested a smaller & less bulky rocker-type switch such as this :-
http://cgi.ebay.co.uk/12V-Black-rou...arts_Vehicles_CarParts_SM&hash=item4837519630
OR this (IF you a "roof power is OFF" reminder light) :-
http://cgi.ebay.co.uk/12V-Red-Illum...arts_Vehicles_CarParts_SM&hash=item4838c2948c
