ok, so i decided to replace my speedo cluster bulbs with LED direct replacements, and now it keeps fusing the instrument illumination... any help guys?
many thanks
			many thanks
Dont use a bigger fuse.
Bigger fuses would be needed if you were using more current. Leds will be less then the bulbs.
Dont help when you dont post whats leds you've put in.
Aren't I right in thinking less resistance in a circuit creates more current though?
So if the resistance of the LED is less than original bulbs then there will be more current
Not talking THAT much big of an amp difference but enough to blow the fuse. Wires have to be safe still!
Fuses are designed to blow if the current goes up at all
