diesel performance
diesel performance
Dug secretly wins Banzai !
Sorry bout that Dug, not used to someone else arguing so strongly on here ;)
So if you said Dug, YOU A WINNER !
(Mental note to self, read BEFORE typing in future !)
Barakka
Banzai
Because he doesn't listen, and needs things spelt out to him!
For the record, I have driven a 1.2 Bravo on hire. Like all Bravos it's a great little car, but I don't think I'd swap it for my JTD!
Time to put this thread to bed I think!
I still don't know....
now , i still don't know how to adjust that dieselpump myself? Maybe Joerg or Marc can help me out??
Don't start over again....!
sietse
Re: I still don't know....
Sietse,
The TD100 has a lucas injectorpump which is different from mine brava with the bosch ve pump. However the bosch pump is adjusted by a screw just above the 4 tubes running to the cilinderhead. Maybe a simular device is fitted to the lucas pump. Have a look at it.
Sorry can't help you any further, maybe Joerg ?
sorry, it's 200
i also own a JTD 105 GT and i'm sorry to tell you, it's only 200Nm. You can also have a look at
http://www.kummich.de/bravo19gt.htm
It's a german page, but it should be possible to gather some info for you.
There are several chip tuning kits available, that raise to approx. 120PS and 250Nm, but they cost about Euro 800,- and i don't think it's worth that much. Also you will definitly stress the engine a lot...
Br
powerhawk
thanx for the info...
Thanx for the info. And you're right, It's probably better not to mess with it to increase performance. The car is quite okay as it is right now...
Greetz!
adj. dieselpump
i had to open the dieselpump; then put in a gear and move the car until the screw was visible (can only by seen when using a mirror and a torch) then turned the screw a half turn clockwise (with an 4mm imbus (hope that tool is called so in english) which i had to bend first)
i'm sorry but my english isn't good enough to describe that more exactly. but this or next week i will readjust my dieselpump. i'll take some photos and if you give me your emailaddress, send them to you. (or is it possible to post photos in here?)
thank you
I will try that! if you could take some pictures it would be great. BtW, where are you from ? I'm from Belgium.
P
3
935
paull
P
S
2
655
Dark Lurker
C
2
793
Dark Lurker
B
2
612
Sabre 23
S
