Diagnostic software
Diagnostic software
masturbation
Does anyone know of some good software that will tell u things about the p (system) for example:
HDD Heat
Memory usage
CPU Usage
Etc.
I know a couple of these things can be found out in xp but i would like all the info together.
Its mainly to find out the heat of my pc and if its being cooled properly.
Cheers(y)
So what your after is Sys Info progs?. Diagnostic progs test your hardware and make sure they pass a series of tests without failing certain parameters. One good hardware check program is PC Check.
Boots up off a floppy and can test litterally everything on your PC and can even predict the amount of useful life your Hard Drive has left.
ooo snazzy cheers(y)
Hmm I have this and never noticed anything usefull in the diagnostics (for testing hardware). I use it mostly for windows password resets, and fixing MBR's and partition tables when theres an unscheduled powercut and 400+ computers get turned off :rolleyes:.
I've used it a good few times, all the hard disc manufacturers software in one place, ram tests, mb tests, partition tools etc.
