Diagnostic complete..here are the codes
L
Lemon/Michael
original thread here
http://www.network54.com/Forum/15639/thread/1231492322/last-1233216138/Issues+..diagnostic+check+performed..can+you+help-
Hi just completed a check the codes thata ppear are
PO304 - Ignition Failure Cylinder 4
straneg thing is i bought an ignition coil when this error initially came up..i replaced all 4 coild and stil the same error comes up?
PO105 - Manifold Absolute Pressure Sensor Circuit
any idea how to fix..and possible costs?
linked to my other post?
http://www.network54.com/Forum/15639/thread/1233492464/last-1233576782/is+this+bad---
PO301 - Ignition Failure Cylinder 1
PO300 - Ignition Failure (generic)
please help
plugs, leads and coil pack :)
start with plugs
She's a monster soon to be revealed :)
If they didnt want it stripping they shouldnt have used nuts and bolts :)
have installed new ignition coil and leads
and sitll got same error?
did a rest of the code?
reading that again, manifold preassure sensor is simply a sensor, cost me £40 for my motor factors and took 5 minutes to put in
the ignition coils, ill have that doing to spark plugs, but when i read ur other threads, uv got problems with ur cooling, maybe the coils are failing becaus eur getting oil on ur plugs? take ur plugs out and see if they are dry. also see for and mayo in ur filler cap and any leaks around the block
C
636
ChrisKnottIns
C
K
4
388
M
J
57
3K
Dark Lurker
