General Cylinder head torque settings
Toonarm
Scarborough
Ducato 244 (04) cylinder head tightening sequence and torque settings. I have tried downloading manuals from the forum but can’t open the ones applicable. Does anyone know where I would find them please.
Model
Ducato
2004
Mileage
74000
You have not supplied engine type/capacity. Presumably diesel, but can be 2.0jtd, 2.3jtd, or 2.8jtd.
Try here. You may need to scroll down. Tightening order is given, but is basically working outwards, with diagonal selection. Torque 60Nm, then again at 60Nm, then 180 degrees.
@bugsymike has Autodata book, and may be able to confirm.
Is this OPs vehicle?
Sorry, I Don’t know who OP is.
Does anyone know if I have to remove the intake manifold and can I remove the exhaust manifold and leave the turbo in situ?
OP Original Post= you.
I haven't worked on that engine in a FWD Ducato most of mine were rear wheel drive Iveco Daily's which are much more accessible to work on.
I suspect you will have to remove oil pipes on turbo and both manifolds , you will probably find the turbo is bolted to the engine block also.
Some engines had an oil pipe to head at bell housing end.
It is all fairly basic, so if you take your time and note where everything goes it should be fine.
Thanks buggsy. Really appreciate your advice. Sometimes it feels like there telling me off. Anyway, I’m still struggling with my head cylinder head problem. Do I remove the intake manifold? Will it come off with the head? Can I just undo the exhaust manifold and remove the head or do I have the turbo to dismantle?
From working on the later ones 2.5 and 2.8, I think you will find access is the main problem, so the more "junk" you can get out the way the better to see what you are doing.
I would say take photos as you go, if it is your first time as it can be a bit of a learning curve.:)
It may sound silly but if you go on the internet and put your engine series and engine in the search you will find some old engines photographed for sale on eBay etc. with the ancillaries on which may give you a idea of how to proceed.
The old Ivecos with basically the same engine, being rear wheel drive four nuts behind the headlights and a few hoses then the whole radiator and grill etc. came away so you could see easily what you were working on.
When you have the head off I would stress clean all the thread holes for the cylinder head bolts and have the cylinder head machined flat, this may involve removing the cam and valves but must be done carefully so all parts including any shims and valves etc. go back in exactly their original position.
One other very important point, head gaskets do not just fail, so you need to find the cause of the over heating otherwise all your hard work will be ruined on it's first journey!!!
It is a big undertaking for your first time, but with care and asking if you are not sure about something it should be possible, there are several owners of older Ducatos on Forum so I am sure you can get advice.:)
Does anyone know if the cylinder head bolts are the stretch type bolts and have to be renewed?
If you look at my reply and the photo of the Technical manual on #5 it doesn't say yes or no for the up to 2004 model but same engine up to 2002 it gives a special note 38 in this photo giving a bolt Diam. 11.5mm which I would take to say means measure bolt and if it has stretched and wasted to less than 11.5mm then replace.
I would say having rebuilt several over the years that I have never had to replace them on that model.
The only argument regarding that is that by now those engines are much older and may have been rebuilt several times and aged over the years.:)
