Technical  Cruise controll
WISBECH,CAMBS
Good morning all
Does the qubo have cruise control as a optional extra? i do alot of motorway driving and cruise control would be very handy,and i would like to look into fitting this to my fiorino [qubo]
Will stalk and loom from punto grande be compatible?
Luigi
Good morning all
Luigi
Grande Punto doesn't have CC I believe so I doubt you'll be getting a stalk from one of the. Can someone post a pic of the steering wheel and stalks / shroud from a Qubo / Fiorino as if similar to a Bravo you may be able to knock something up from Bravo / Stilo parts.
I did wonder about the stillo, it was the stalk control i need to get right,and how it fits in relation to the other stalks?
All i know is there is a multi plug taped up under the shroud
luigi
Have a quick look at the Stilo sections how to install CC guide, it's long winded, but well worth the read, and if the setup is the same you should be able to use it to get CC working (y) It worked fine retro fitting it in my Stilo :)
so i'll need to get a new shroud to allow for the extra cc stalk?
so all in all this project should be plug and play then?
so far all the other things i've done haven't required a visit to the dealer [genuine fiat rear parking sensors.meta alarm,towing socket]
luigi
luigi
What you looked at the Stilo guide yet? All the answers to your questions should be in there ;)
Ok read through guide, all looks fairly simple.
found alfa 147 stalk on ebay £47, just need shroud, so i give fiat a ring in the morning,i guess i need to sit down for that price as it looks as i need the top and bottom.
luigi
luigi
Have you bought and installed your Cruise Control yet?
If so was it just a matter of plugging in the stalk (plus modifying the column shroud) or did you have to buy extras like servo motor and linkages?
R-V-M
R-V-M
If compatable it'll be plug and play or install and wire in, no servos or linkages (y)
