Mar4ix
- Joined
- Feb 4, 2011
- Messages
- 248
- Points
- 144
Punto mk1 , 1.2 , 8v, '99 engine.
what would be crankshaft sensor fault ?
Ive noticed couple times, i have difficulties start it from cold, not always, but sometimes.
Also she is running rough, feels like misfiring, but not proper misfire ... and emissions are 0.6 % on idle, and 3 k revs, 0.5 % ... causing me fail MOT. New lambda, new temp sensor (well a year approximately), maff sensor put from another punto, no change at all. vacuum pipes are new, those fancy one , white color.
wonder if old one was hard type pipes, those what i have now are soft silicon one, was buying for nissan skyline turbo charger , but didnt use them.
Timing properly set. Compression perfect. , headgasket changed. Good oil.
Planing try put another ecu also.
thanks
thanks
