43576
Two weeks ago, I had an issue starting my car, a Panda 1.2. It was a cold morning, around 13°C, and before heading to work, I found that it would crank but not fire up. I tried three times then the engine started. Over three consecutive days same problem.
I bought new spark plugs, but the problem persisted.
Upon further investigation, I discovered that the negative wire from the battery to the body was covered in corrosion green mould. I replaced the wiring and the battery clamps.
Now, the car starts on the first attempt without delay. However, I've noticed that the starter motor doesn't turn quickly for the first two seconds before firing up.
Could this indicate a faulty motor? I tested the battery before starting; it read 12.5 volts but dropped to 9 volts while starting. The alternator generates electricity back up to 14.2 volts once the engine is running. After turning off the engine, the power slowly decreases from 13.2 volts to 12.6 volts.
Is this normal? I don't think there is anything wrong with the alternator.
