Technical Coolant temp sensor
Yellowpuffin1
Poole
I have a 1.9l td ducato/boxer
I am struggling to find a replacement coolant sensor for radiator
It is on the ns of rad near bottom hose
It has 3 terminals and all the ones I can find have 2( as I would expect)
Any idea where I can get one
I assume this controls the fans
Model
Ducato 1.9L DT
2001
Mileage
50000
My 1990 Talbot Express used a similat item to control the cooling fans. Mounting appears identical, but mine had short wire tails to two pole and single pole connectors.
Fantastic thanks so much
I was struggling to find this
My fan sometimes continually runs on after I turn off engine
I am assuming sensor is sticking closed?
If rad temp is higher than switch off temp fan will continue to run until temp drops to switch off temp- that was normal.
Maybe time to service the cooling system.....drain and flush
