I would assume the turbo 1.4 has better fuel consumption which could be a point to remember.
But on a side note...is there anyway to have the Sport button removed...I'm wasting too much petrol!!!:devil::devil:![]()
I think you're taking the easy way out.
can you not work out where it is coming from? Not suggestion you fix it, but i'm really curious to see where it is actually leaking from.
If they keep suspecting the pump, and it's not - then it is probably the O ring on the water rail as it comes out of the pump and accross the front of the block.
OR it is from around the pump, and the casting on the block is flawed.
