- Joined
- Feb 24, 2021
- Messages
- 51
- Points
- 70
Hello all and thank you for your help.
I sort of have the same question but slightly different than this one.
www.fiatforum.com
Bravo 2 1.4 T-JET
I have just replaced the thermostat and filled up with 50/50 coolant and water in the reservoir up until the plastic marker inside the reservoir. We started the car with cap off and let it idle. I opened the heater and switched off the A/C. After a while the pipe between the thermostat and radiator became very hot telling me the thermostat opened. But, and this is my question: when we opened the plastic drain plug at the bottom of the radiator, no water came out. I know the radiator is not blocked because when I blew on the pipe connected to the thermostat, water came out from the reservoir.
At what temperature does the radiator fan switch on? The fan also switched on.
How can I be sure that the radiator is filled with water?
Thanks for your help.
Coolant 1.6 multijet bleed | FIAT Bravo 2 (2007+)
I am replacing intake manifold due leak (plastic crap). I want to know if there is any specific trick to bleed fiat bravo 1.6 multijet cooling system? Any advices?
Bravo 2 1.4 T-JET
