Technical Complete Door Component Teardown??
JayEm
Stiloooooooooooo
Hi
Am I right in thinking I have to completely dismantle the door in order to replace this part:
attachment.php
Its the bit that holds the lock barrel in place; I accidentally rounded off the torx head last winter when trying to lubricate the mechanism after it kept freezing up. :cry: Any tips?
Thanks!
Thanks for the help. :p
Tips for anyone attempting to dismantle the door:
- The torx screws holding the lock are T40 size
- The window comes out and goes back in fairly easily but its best if you have a second person there to help. Pilkington glass is stronger than you think so even if you're a little heavy handed, it'll still forgive you!
- You will inevitably break some of the trim clips.
- When removing the inner panel, you have to pull the top towards you and then raise it to clear the window mechanism.
- The bowden cables for the handles need to clip back in exactly as before otherwise they won't work!
- Don't forget the LED cable.
