General cold cathode tubes
cheers tom :)
the blue set i have already dont have any computer fixing on them, so im gonna pinch the inverter and switch from that, they seemed to work ok when i wired them up briefly to test them a few months back
i will soon tell as they will be arriving next monday as im a cheap skate on p&p :D and dont really need them for a few more weeks, but i still need to make the number plate glow from behind to pass MOT, so gonna be bodging something together for this
thanks again everyone for all help :)
woohoo, the tubes came today, so im starting the lightbox for the number plate :D
but the ones that came have got all the computer connections on them and i cant find my old set which just had +/- and a switch :(
how would i go about wiring them up to my car :confused:
No sure, it depends what kinda connectors they are etc. If it's a four pin molex connector, then you should have 0V, 5V, 12V and erm, 0V I think, but I can't remember which order.
Ebuyer's cathode tubes work fine on a cars 12v supply, but computer ones are very fragile. I had some in my boot but they cracked so I gave up on them. Gaz, you'd probably be better off mounting the tubes where nothing can hit them and where they wont be bent.
Wiring: the yellow wire is the +12v and the black is the ground connection. Just use these, the 5v connector isn't even used for neons.
GhostWKD said:
gaz, you need to use the lil bluey turqouisey box so cut the wire after that not before (ie you want when its working, your +/- followed by box, which then loops to cathode tube or two :cool: )
eh :confused: :p
the tubes will be behind the number plate, so it will shine through it, they will also be encased in a perspex box, which i started today :D
im searching high and low for the other set that i have cause they dont have the computer connections on them, but i think on that set, yellow is + and black is -
unfortunatly not alex :(
i might experiment myself with the wires, cause im thinking aslong as i got that little box and those little connectors that go into the box, then i should be alrite.....hopefully :eek:
whats the worst that could happen :eek:
pghstochaj said:
haha, did you have to ask?!
lol
:p i was more concerned about what would happen to the tubes, will they explode, like some dodgy neons (n)
if my wiring catches fire at least i can put my extinguisher to good use :D
