Italian Coke Can
- Joined
- Nov 20, 2005
- Messages
- 487
- Points
- 103
If you have a smelly engine the fumes will escape and be ducted into the cabin.
aye all the hot air will escape right to the fan for the interior, so no cold air flow in the summer i beleive, unless you leave that bit and cut the sides out haha
aye it might not happen, but your interior fan sucks the air in from the bottom of the windscreen does it not??? if that air was coming from under the bonnet through the rubber seal it would be alot hotter, definatly in traffic. i dont mean through the sound deadening or anything, just were it gets sucked in.
i could be wrong but the way i look at it that has to make sense haha.
anotherway of doing this is to space the bonnet up on the hinges by say 5mm so undo your bonnet hinges put 5mm of washers in then retighten and repeat for the other hinge saves cutting and sourcing a new seal!
Is there anything else like this mod i can do to squeeze more power from the old girl???
a good full service
oil
done
oil filter
done
fuel filter
mpi soo not serviceable ?
spark plugs
not done should get done next
ht leads
to be done at the same time as the spark plugs
gbox oil
how?
air filter
focus kit fitted
ash
correct alignment and pressure in tyres.
close windows![]()
