Hi and thanks for all the advice,I don't have any knowledge of scanning codes or access to any sort of code reader,so would have to take it to a garage,which I really can't afford right now,is there anything that could cause a misfire that I will be able to check/eliminate myself,without taking my engine/electrics apart or plugging a computer into it,bearing in mind that I'm not a mechanic? The exhaust baffle material has started coming out of the exhaust,looks like my engine sucked in a wig! could that have anything to do with it??
have you had ANY warning lights show..??,
material coming through exhaust is a bit odd..!! not too sure it will cause a misfire though,
are you 100% sure the correct leads are going to the correct cylinders ?,
where are you based?, can you get one of your "knowledgable friends" to read the codes for you as a favour - takes approx 5 mins if you take the car to them and open the fusebox cover by your knee,
Charlie - Oxford
