What do you guys think about buying a clutch kit from Ebay? They seem to be a lot cheaper than my local place is quoting but is it false economy? Is there a brand you would recommend?
I recently bought a Valeo dual mass flywheel for my JTD from an Italian eBay seller for the Euro equivalent of £210 delivered within 3 days. The same part from Fiat was £460 +VAT.
Can you supply me with a link?![]()
Fiat use Valeo for clutch parts, so if you bought Valeo parts from an eBay seller, or local motor factor, they would be the same as supplied by Fiat, but much cheaper.
EDIT: UK company here:
http://www.ebay.co.uk/itm/Clutch-Ki...arts_Vehicles_CarParts_SM&hash=item416532c532
has the 1.6 Valeo clutch kit for £85 delivered.
They don't list one for the 1.8 but you could ask them. The 1.8 kit usually comes without the thrust bearing/concentric slave cylinder, so you would need to check.
This is the one I bought:
http://www.ebay.co.uk/itm/836034-Schwungrad-FIAT-STILO-Multi-Wagon-192-1-9-D-Multijet-150hp-2005-VALEO-/110867313373?pt=DE_Autoteile&hash=item19d034f2dd
Valeo part number 836034. It's listed here for the 150 MJ, but was the correct part number for my 115 JTD. There are several versions of the Stilo DMF.
Check you get the correct one. I found some eBay sellers were listing the same part number DMF for all diesel Stilos.
Valeo online catalogue here:
http://www.valeoservice.com/html/unitedkingdom/en/
Valeo or LuK No need for fiat as already said they are Valeo units anyway.
On a tangent... SKF, Gates or Continental (ContiTECH) for all things belt related... Lucas, Phillips or PIAA for bulbs... NGK for spark plugs and finally... FRAM or MANN (MANN-Hummel) for filters
My question is has anybody ever fitted the 150MJ clutch into a 115JTD before? Not sure if the above quote is saying its a universal fit or the supplier has just incorrectly specified the correct part numbers?
Or has anyone got a clutch to recomend for the above purpose?
Going back to the original question, can anyone answer it? Thanks![]()
Mike s :If you find the Fiat OE numbers off eper then cross check with www.partsbase.net you should find the answer to interchangeability and then to your question.
If that was the original question I must be invisible![]()
