greenfingers
- Joined
- Feb 8, 2007
- Messages
- 6
- Points
- 2
I have a problem with my daughters Seicento sporting, the clutch pedal mechanism failed I thought it was the clutch cable but on checking I found it to be ok after dissembling, I then checked the connection to the plastic quadrant and found that the cable connection bore had broken. So tried to source a new quadrant from a main dealer, They could not identify the part only the pedal assembly and cable and wanted £23. Their manual does not show the the quadrant assembly.
Is is it possible to source this as it is only a simple plastic moulding.
As a qualified engineer I have not seen such an abortion to convert LH to RH drive clutch operation and as to access under the dash this is extremely difficult.
Any suggestions ?
Any suggestions ?
