I'm in the middle of replacing the clutch on a 2005 1.2 8v LHD panda and the release bearing is cable operated. I needed the loosen the cable to get the gearbox out but now I need to put it all together and adjust it so it has the correct tension and travel.
I found a picture that states that the clutch pedal needs to have 140mm of travel between pressed and depressed I also found a picture that displayed the procedure for a seicento and that stated that the travel should be 120mm. The 140mm version is for the panda they said but not which type.
Can somebody share the correct procedure for this panda type?
