I have a 1994 Cinquecento it is only running on one coil. I know the two coils are OK as I have swapped the LT connections and each coil works OK as do the HT leads.
The problem is associated to the wiring from Pin 19 on the ECU. However I have tested the output from the ECU the voltage from pin 1 & 19 is 14v, and there is 14v at the plug but only the coil connected to Pin 1 works. I have tried different coils, new leads, new plugs, new cabling from the ECU. One of the coils is the original and one is from a Punto not sure is there is anything different about the coils that would stop them working together.
