I believe it is just glued on to the door, to it would need prising off.
The sticky residue you would see behind it will best be removed by soaking it with a petrol-filled rag (best to do it outdoors and not while you're smoking). Dab the benzina on.. give it some time to work on the glue, and then just wipe it to remove it. You'll need to repeat a few times probably.
Ralf S.
Wind the window down, remove the trim that runs along the door (mentioned above). Pull out the side channel which reveals the two torx bolts. Careful they don’t drop down inside the door. Then it just pulls out.
I’ve got to do one tomorrow so I’m going to do a video.
I had intended to but I couldn't find the replacement one. I have several but if you saw the state inside my garage and my garage extension which has become a Fiat parts store you would understand why. Slight delay until I manage to find them. Can find two for the other side, but not this one!!!
Pictures, pleaseI have several but if you saw the state inside my garage and my garage extension which has become a Fiat parts store you would understand why.
