steveb1250RT
Thanks. Well the P0101 code was evident at first and just yesterday I got the P0106 code and reading from the OP’s posts I am experiencing the same issues.Water will be air con condensate. Its normal and worse in hunid weather. Always keep an eye on coolant levels though.
Limp home is quite possibly the evap solenoid as suggested above. Ive had exactltly this. The parts from Fiat are expensive so maybe try and get fom a decent parts place locally. MES or a diagnostic will confirm usually what the issue is.
Process of elimination really. But I am also thinking evap solenoid at this stage.
Thanks for the suggestion on monitoring coolant levels.
Fortunately I regularly check fluid levels on my cars and bike so hopefully no issues.
