Change door stop Fiat Panda 2008
jangodog
Hello. The two front doors on my Panda needs new door stops and i wan't to know if there is a guide somewhere in this forum? I know there is 4 screws on a plate on each door that has to be removed but where do i go from there?
jangodog
jangodog
Hi, and welcome , :)
to make sure we are discussing the same part, ;)
what part number here;
http://eper.fiatforum.com/eper/navi...INT_MODE=0&EPER_CAT=SP&WINDOW_ID=1&GUI_LANG=3
I suspect part #7 - door check strap;)
but it could be the locking latch#3 here;
http://eper.fiatforum.com/eper/navi...3&WINDOW_ID=1&SGRP_COD=29&SGS_COD=0&DRW_NUM=3
Charlie
Hi thank you for your welcome and yes your so right, it's part nr 7 door check strap:)
Are there any guides/tutorials on how to replace the straps? Hope i don't have to take the entire door apart:)
Regards
jangodog
Regards
jangodog
not seen any for a panda..,
maybe covered in a manual (@Portland_Bill);)
otherwise use the punto GUIDE for general info / guidance:)
https://www.fiatforum.com/punto-ii/421570-door-check-strap-installation.html
https://www.fiatforum.com/punto-ii/429823-door-check-strap.html
Hi, okay just have to look carefully when i take the old one out:)
Thank's many times for your help my friend:)
Regards
jangodog
According to the official workshop manual, it is removed from the door from inside, through the speaker aperture.
So the door trim has to come off, then the speaker removed. I think the speaker is riveted in, so you'll need new pop rivets, or some screws and captive clips.
Holy moly, i was worried about that:( Thought it could be done without taking the door apart. Well i'm thinking twice about messing with that:) Haven't purchased the check strap yet:)
Thank's anyway:)
Regards
jangodog
Hi. Where did you get workshop manuel for the Panda? Can't seem to find it unless your paying for it:)
Regards
jangodog
