Technical  CD Player
Technical  CD Player
Archiew05
Newcastle
Hi, my 2009 Fiat panda cd player doesn’t work, it doesn’t take in cds and says CD error. I have read solutions such as disconnecting and reconnecting the car battery but I’m not sure I’m capable of doing this, or to take the fuse out for the radio/cd system and then put it back in. In which case, how do I do that with the fuse and which fuse do I need to do it with? Any other solutions would be greatly appreciated. It has done it before and somehow fixed again but not sure how. Thank you in advance.
Model
Fiat Panda
2009
Mileage
49000
I doubt taking a fuse out and back in will do anything
If you want to try it just disconnect the battery negative, it acheves the same thing and easer to do, the negative is on a cam lock
Sound like a typical Google AI answer
Solution when under warranty was to take it back to fiat they changed the head unit, which kinda of points that the err is normally internal to the head unit
Retail CDs stand more of a chance than home copied one of reading successfully, clean the CD
Stripping the unit down and cleaning the laser with isopropyl and cotton buds is an option but it's success rate is fairly low
This one is already open
Just push on the lever to this position
Keep you fingers away from the back when you push it open, if tight it wil give them a wack
Unlike the guy in the video
As long as it's the original OEM radio it should remember it's security code
The older cassette head units don't, but does not apply here
Unfortunately, after disconnecting the negative and leaving it for 30 minutes before reconnecting, the cd player still behaves the same and displays the cd error message
As expected
It almost certainly an internal fault, such as a faulty laser. Miss aligned laser or dirty laser
A laser cleaning disc will not work on a slot cd so not an option
There's several options
The simplest solution would be to put your songs onto you phone
And use something like this
Which connects to the phone by Bluetooth and transmits via an empty radio channel, this always works
If your radio has USB you could put your songs on the a memory stick
Aux cable is a bit hit and miss, if you toggle the source button on the radio and you see aux come up it should be fine
Or replace the head unit
As expected
If a laser cleaning disc does not work, is not going to be an easy fix, and probably not worth the cost of getting it repaired
Thank you for your help, will look into it further
Ello :)
Yes, I've been using a Bluetooth FM transmitter for years now.
Suits me just fine for playing mp3s from my phone.
With a few conditions:
It picks up interference when we're in a city or sometimes from passing traffic.
Not often a problem for us out in the country, but if you're in urban areas or heavy traffic it might get annoying.
You can set the frequency, finding one that's reliably free from other broadcasts might take some time.
Due to Fiat's odd spec of lighter socket it sits quite loose and can easily lose connection if knocked
It seems strangely quiet. So I put phone volume to max, then raise the stereo volume to about 40 or so.
None of this bothers me too much because we don't use the car that often, very rarely in traffic and I don't usually listen to music in the car anyway.
It's just there for occasional long motorway slogs or if the other half feels like an early-noughties euro-trash rave :) Which does happen 😐
But if you're serious about your driving tunes I'd suggest the bt transmitter is sub-optimal
Just as a side note I got an old PlayStation PS3 slim working again by cleaning the laser this way
All so we could watch a Luis de Funes Blu-ray we'd bought by mistake :)
But yeah, slot loader would make this much more difficult
