Technical car seems to have a dead spot
Crom1
Good evening from a newbie,
My Punto Grande is an 08 plate with 38000 on the clock seems to have a flat/dead spot when setting off in first gear.
Just as you set off and press the the accelerator the car seems to die for a brief second, its annoying because you push the accelerator down more and increase the revs to get over flat spot.
Any advice Please.
Thank you
Thank you for your reply
the engine is a 1200 cc and was last serviced Nov 2017
Hope the information is of help.
Thank you.
Thank you
Flat spot at take off ?
The ECU doesn't react fast enough to the air amount increase and the mixture goes lean, or the mixture is already lean… I'd check (for):
- leaks in piping/manifold
- throttle body
- MAP sensor
Do you feel like the engine kind of hesitates when re-accelerating after a slow down while Driving ?
BRs, Bernie
If someone here helped You fix -or better, understand- your issue, hit the thanks icon @ bottom right corner, it's free and makes us feel helpy ;-)
Thank you for time in replying to my question, I will take a look at the answer and go through them on my car.
Thanks again , have a nice weekend
Thanks Bernie, I will go through your answer as well.
Have a nice weekend
