If you go down scrap yard, what you have to do is get the ECU, BSI (behind the fusebox) Locks (petrol cap and boot lock, but if you get one off a remote locking car, you dont have to worry about the door locks so much, but would be handy) and thats about pretty much it, probably takes a hour to fit it all. no problem. There is a scrap yard down here that does them for quite cheap (got mine for around 25-35 quid i think so you shouldnt have to worry.
Just because his code reader wont connect it could be the inncorrect type
If you wish to get a cheap VAG-com cable or KKL cable off ebay cheap
or an ELM 247? *current version?*
Get Multi Ecu Scan - (Fiat ecu scan) trial edition - and get the code
Better to spend £10 to potentially fix it then give it a drastic diagnosis and be swapping stuff that aint needed
My guess is that, as Ziggy says, you need the right ECU reader (also see below); but if you do need the full set, as described above, there's currently a set for sale for £70 (haggle!) in the forum's Classifieds section -- here:
LOCKS, ECU & CLOCKS SET (Set consists of: ECU, inner & outer fuseboxes, Clocks, ignition barrel & 2x key, boot lock, drivers door lock, passenger door lock, locking petrol cap, all coded/matching removed from the car that have covered around 63,000)
Otherwise, if you don't want, initally, to go down the route of using a laptop, etc. to read the ECU, I've started carrying one of these around -- it's a handheld reader: which works on my Punto.Good luck...!
