Hi my sons 2002 Punto is due for a new cambelt. Have read several threads and most refer to setting the timing to TDC. The engine had two cycles, one on the firing stroke the the other on the non firing stroke. The question is. If the engine is set with the timing marks as per the recomendations, the old belt removed and the new one fitted without moving either the cam or crank pulleys, does it matter if it was on the firing stroke or not. I know you can look through the bel housing for marks on the flywheel but it is difficult to get a good look at the flyweel below the hoses etc
