Technical  Caliper bolts
Truckcab79
Put new discs and pads on today as the previous owner thought that new pads on knackered discs was a good idea. Calipers bolts were a bit chewed up. Managed to get them off but would like to replace. New pads didn’t come with any and can’t seem to find them listed anywhere. Maybe because they’re just a standard sized bolt?. Anyone point me toward them I’d appreciate it. It’s the caliper to hub bolts I need. The larger diameter, double castellated ones, not the caliper / pad slider ones.
Fiat Doblo cargo 2015. 223 platform. Front discs.
Thanks in advance.
I know from annoying experience the bolts are mare of cheese having sheered off a calliper slide pin bolt in the slide pin! They are not a standard pitch bolt but you can source them on the Internet with replacement slide pin kits. I was on a Friday afternoon when mine sheered so I mopped up my local engineering shop and he drilled and helicoiled the pin and gave me a suitable bolt. Meanwhile I ordered a kit that came from the EU after all the usual delays for when I next replace the pads.
If it’s the hub carrier bolts that the calliper carrier attaches to I believe they are standard pitched threads but can’t tell you the size off the top of my head.
