Technical  Calibration issues
Fiatinaus
Nsw
Hi all
Just did a clutch replacement on a friend's fiat with the duellogic transmission
Managed to sort out the starting issue but now it won't let us even commence calibration
Numerous issues
Hydraulic pressure
Car must be in neutral before commencing but it is
One test is asking us to disconnect pump
And psi must be above 45 psi
But everything was reinstalled the way it came off
Anyone had similar issues
Model
500c
Year
2013
Mileage
133000
The car rolls freely so assuming it was in neutral
With the robot removed looking at top of gearbox
What position should the selectors inside be
See this thread...
Stupid system
Now it seems to be in reverse and won't let calibration commense
Also says it cannot establish connection
(Like it not communicating with gearbox )
Changing the gearbox back to neutral seems easy enough but how do I manually change the robot back to neutral position
