Technical  Stereo Upgrade Issue
Dempo
Shropshire
Hello, I’ve got an issue with the pin configuration on the adapter cable for my stereo upgrade. Fitted it, no power and noticed this. I’ve spoken to the supplier and he checked and said all his are wired the same, looking online, others look like this too. The pic shows the issue, pin configuration on RH adapter is nowhere near the pins on the car. The LH one is fine, am I missing something? Cheers
You'll need to run a switched live, it's the can bus that turns on the radio I think, that's how you can turn it on with the key out, it should be quite easy to work out?
Is the black plug from the new radio, you'll also need proxi alignment to cure the mileage flashing
Cheers, the black plug is the adapter cable. The grey connectors from the car and the inputs to the new stereo are both female so the adapter sorts this out.
