C&B Cams + UniChip Graphs
Y
YoGiS
Ok I have the graphs scanned and all but how the hell do I set them in???
Ok well 1 day has passed and I got no help, so I will put them in the danish club site and post the link here in a bit then... :(
Re: Re: C&B Cams + UniChip Graphs
if you email it to me i will put it on the forum for you.
Maerin
type the whole link ending .jpg and it shall appear
Re: Re: Re: Re: C&B Cams + UniChip Graphs
that url doesent work for me, anyone else ?
Re: Re: Re: Re: Re: C&B Cams + UniChip Graphs
Hmmm
I will try to upload them to a site then if it is not working...weird..
Re: Re: Re: Re: Re: Re: C&B Cams + UniChip Graphs
works for me ok.
Very smooth curve !
Re: Re: Re: Re: Re: Re: Re: C&B Cams + UniChip Graphs
Yeah it kicks ass...
after 4k you can feel the power big time and keeps going...too bad the car doesnt work right now hehe..but should be no problem...and the unichip has a very nice look also
CB
Can the engine take high RPMs. As per your statement about, you said that the power comes in about 4,000RPM. Our engine can take it up to 6,500RPM. With the cam and UniChip, will increase our redline.
In your country, any advise on a 1.8 FIAT engine using an AR145 QV gearbox, flywheel and clutch set?
Thanks,
Syed.
Re: CB
I didnt get the rev limit modified or anything...
That might do next time but for now I wanted to leave everything normal...
Re: Re: CB
Without changing the engine internals its wise to leave the rev limit exactly where it is. Things could get nasty otherwise. :)
The rev limiter is not just there to spoil your fun. Anyway, you can see from the graph that the power drops off long before the revs run out.
Re: Re: Re: CB
The Marea is back and running :) Problem: Cam Position Sensor... ARGH!!!!
Re: Re: Re: Re: CB
The injector light and all is off now!
Must say the car is a bit "unsteady" in low rpms when in idle...i mean it stays like in 1000 always, but i can hear in the exhaust the noise...and boy the k&n kit makes real noise now especially in low rpms...
Re: Re: Re: Re: Re: CB
Yeah, you will have lost a little bit of idle smoothness. The trick now is to have the flywheel lightened. That will bring it back to normal.
Just as a note, don't lighten the flywheel with a normal cam, you will get bad idle as well. :)
M
4
172
Dark Lurker
M
5
307
M
G
464
garaint
G
