TheGreenMachine
- Joined
- Sep 7, 2020
- Messages
- 9
- Points
- 31
Hey All.
I have a 2011 Panda 100hp and a couple of days ago the heaters stopped blowing hot air. I’ve done some investigating this afternoon, I removed the motor that adjusts the heater blend door, that works fine, but I noticed the the half moon drive gear it operated had a piece of plastic snapped off inside (heater box side) which I assume should be attached to the heater blend door, to open and close it, which is why I have no heat. My question is, is there any way to repair this or is it a case of having to get the dashboard out and replace the entire heater/ac unit from the car?
