M
Mekon
Noise from clutch area
This is the clutch release bearing when it gets dry (ie no grease - so called sealed 4 life) it rattles, after a time it will fail. better to get it sorted at Mr Clutch if u ignore it and it fails it may score the clutch shaft in the gearbox, this is poart of the gearbox casting and is non replacerable u would need a new gear box.
This happened to my wifes car and shaft was badly scored but managed to salvage by rubbing most of the burrs off the scored area and totaly covering shaft in high temp grease.
3 years later and no problems - but a fiat dealer would not do this they would sell u a new box at 800 quid !!!!!!
this car seems to suffer premature clutch failure.
