NickBr
- Joined
- Jan 26, 2019
- Messages
- 63
- Points
- 90
I have a problem with the operation of the motor that moves the flap for the air conditioning air mixture as I write in the title.
Fiat code for this is 46723615 and on it i can read Bosch VMC 180200 1 (07) 0 132 801 124 1 Made in Malaysia 905
Some time ago the error CLI began to appear on the odometer display, and the cooling did not work.
The air conditioning compressor was running normally but I had no internal cooling.
Looking for it I discovered that the flap that chooses hot or cold air depending on the position of the temperature selector rotary switch was responsible.
So I removed this motor and after checking the movement of the flap I saw that it moves easily and normally without getting stuck at some point in its rotational path.
Inside the plastic box of the motor there is a motor and a potentiometer that is probably to check the position of the flap.
I powered the motor with a voltage of 12 volts and saw that it moves properly without a problem, I also threw contact spray on the potentiometer, which also changes ohmically depending on the movement of the shaft.
Now I have to remove the motor from the air conditioning box and turning the rotary temperature selector to turn it to the hot or cold position depending on the weather, and then remove the connector so that the valve remains in this position and I fasten it that way.
If I place it normally and connect it, it will stick either in the hot position or in the cold position.
When I operate the motor out of position it operates normally in both directions.
I have no problem ordering a new motor, but I do not know if the problem is in it or in the air conditioning control unit and where this unit is.
Can you help me ?
Can you help me ?
