DPD
Hello,
I have an Xreg Brava 1.6 elx and the engine is misfiring after getting water up into the engine bay a few weeks back.
Engine light came on at the time, but didnt start misfiring till later.
Revs can surge up and down; also a bit of a meths like smell comes through.
I'd hoped that matters would rectify after it had dried out in my garage but no such luck.
Took it to Kwik fit in Chelmsford for diagnosis as it was the closest garage and got error codes P0202/P0204/P0230/P0300.
According to them 202 is injection valve cylinder 2
204 ditto for cylinder 4.
300 random/multiple cylinders misfire detected.
230 electric fuel pump primary circuit.
I'm hoping its likely that i've shorted out the coil pack and thats failing so if i replace that (and plugs & leads) i should be ok.
Worst case is that i've actually had some water droplets go in the air intake all the way through to the cylinders and i've stuffed the engine.
(but why only 2 cylinders in that case?)
Not sure about the p0230 elecric fuel pump primary circuit, so am off to the library shortly to get the Haynes manual for the Brava so i know more of what i'm looking at.
Any input gratefully received.
Dave
Dave
