Hello,
I've a 1998 1.9 Ducato Riveria camper. The long rear copper hardline failed (puncture in the pipe). I replaced it but cant bleed the brakes.
I've read a number of threads and none the wiser on issue. There's very little (none now) brake fluid even going to the hardline at the back.
The brake pedal was pushed to the floor a number of times after failure (when spongy/ no brakes at all). I can hear air escaping sound from pedal/ master cylinder when cap is on it and brakes pressed. No fluid leak anywhere and the fluid never dropped really from the bowl (i topped up anyway).
Tried to bleed by someone pressing brake. No flow at all to the back now. The bottom bleed nipples on front (left and right) has good flow - temp gave little braking after bleeding, the top on 1 side has some flow and the other nothing.
Have i wrecked the seals on the master cylinder, are my not bleeding correctly or does the master cylinder need to be bled?
Any help appreciated
- Model
 - Riveria 1.9
- Year
 - 1998
