Technical Boot opening while I strat the car!!!
Komárom
Yesterday my Stilo start working with a new feature.
When I starting the car the boot is popping up every time. After I close it back it is not opening again. I checked the wiring and it looks ok. I deleted every failure from every ECU in the car. I tryed to make a new proxy alligment but its ending in Climate controll because it can't write.
What can be the problem? :bang:
Is anyone had similar problem?
Are you just squeezing the key fob as you turn the key and activating the remote boot release?
Had this happen a lot with the 500s with BSM. The learner would squeeze the fob, then I'd send them out to shut the boot. Try putting the key in the other way around to help prevent it if this is the issue.
Thanks for the idea but this was the first thing what I tryed. It is funny but I turned the key with two finger.
I'm still thinking it is the key fob.
If it is old or well worn, it could be flexing, causing the internal switch to make contact.
Take the battery out of the fob and start the car. If the boot opens, the fault probably lies in the body computer, but if the problem does not occur, the fob is the cause.
is there a button in the stilo to open the boot from inside?
bit of a pain having to take key out of ignition and hold boot popper on the key and start the car again?
Re: Boot opening while I start the car!!!
Soooooo!
The problem is solved. :slayer:
Thoose peoples had right who choosed the key as the guilty one.
I'm still don't know why but it was the key.
I removed the battery from the key to check the surface of it, is there any corrosion or not.
It was perfectly clean but since that everything is working as it should.
The annoying is that I tryed to start the car with an other key what is not equipped with buttons and the same is happened with that ( the boot popped up), but now I know why. Because the buttoned key was in my pocket. :)
So something went wrong with the radio inside but was fixed with a "reset".
Thank again for the helps.
