boot lock
boot lock
deano
recently, the lock has failed on my boot of my 1.4l Bravo.
anyone have any tips?
when u mean failed? How do you mean exactly?
Key not working?
Have you got in car release to use tho?
My Vid:
http://s329.photobucket.com/player.swf?file=http://vid329.photobucket.com/albums/l362/mikedenney/MyVid_0001.flv&fs=1&os=1&ap=1
hey there,
when you close the boot, usually self locks. But currently just closes and does not lock. It's just permanemetly unlocked.
there is an in car release next to drivers seat but has no effect. can u help?
Have you tried putting your key in to unlock it again? and if so what happens when you turn the key?
Kris
next to the drivers seat,is it a pull up lever? If so itll be cable and could have snapped or come off the lever OR its not working inside ya boot..
Had this problem inside my polo's boot,its open all time.
Open ya boot,take the plastic cover off and look to see if anything has snapped off or come off.There should be like an arm that pulls the mechanicism up/down when you pull the lever inside the car,AND when you turn the key.
Its hard to explain the way i did it but i had to use tiewraps in the end on the polo to keep it shut lol
Mike
My Vid:
yes, we tried that and no response.
when the boot is open we had to use the key to flick the internal lock over to the 'lock position'. But then could not close the boot as already in locked position and the lock does not fit into the lock groovy. Make sense?
Right,you say you can close ya boot but is 'open' mode? If so,you'll just have it bein open all the time,no one will know only yourselves.
Saying that,once ya boot is closed,can you not use ya key to lock it?
My Vid:
yes, it is a pull up lever. thot it might be that and if it is wd it be easy/cheap to repair/replace?
R
5
447
S
P
5
285
M
A
1
666
S
C
6
440
M
M
4
653
M
