Technical BMC Air Filters
Wrexham
Just been searching for an Induction Kit for a sei sprting on the net and came across these BMC Air Filters, they claim to give you more bhp ranging from a 3 to 15.
Are they work the money or should I just stick with the normal kits.
Check out this link to read it
[http://www.passionmotorsport.co.uk/BMC7.htm]
Gaz[^][^][^]
Looks Good, Drives Sh!t.
I would say that they're very good, but probably not worth the money! I have one on my 98R Sei Sporting, and there's a real increase in torque (right from 1500rpm), flat spots are gone and it breathes much easier higher up the range. Looks the absolute nuts too.
However, performance per £ I guess isn't that great. Boomy on motorway hills too...
Cheers,
Darren
Cheers,
Darren
I might have to save up for one of these then, i'll make do with the standard airbox for the time being, I might even try to fit my old Uno induction kit onto it.
Gaz[^][^][^]
Hi...
I’m thinking on Ractive air filters with a steel induction pipe added to a silicone 90º Turn…
What do you think about it?
best regards
HVal
i have a K&N induction kit fitted and love it to bits
as far as performance per £ goes - lets be honest when you start with 54Bhp you take all the extra you can get ;)
SEI-POWER
hval, thinking of something like this?
Pete.
Cinq sporting 1242cc
http://mysite.freeserve.com/close_to_cracking_up/
<blockquote id="quote"> face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by fixitagaintomorrow
Pete.
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Yes that’s it fixitagaintomorrow,
but i don’t have that plastic cover on my throttle body .
Where can i find one like your’s???
P.S: 54HP,1.1 Engine
best regards
HVal
One more thing, which is the exterior diameter of the plenum?
The ractive filter interior diameter is 3” our 76 mm I probably have to use a silicone redactor in the end of the induction pipe to connect it to the plenum, it is true!!!
best regards
HVal
Lancia Y Elefantino Blue
