Cos they don't really know!
Once I have unplugged it and sent it off to be refurbed, is it a case of just plugging it back in? To Revtronic for example?Cos they don't really know!
Would you replace with the third party stereo such as the Wiston from AliExpress instead?Once I have unplugged it and sent it off to be refurbed, is it a case of just plugging it back in? To Revtronic for example?
That's a big "it depends" if it retains its (electronic) address then it should plug and play. If the whole thing gets reset then it requires the CanBus ECU to be told there's a "new" module - Proxy Alignment. I used a second-hand module from an Alfa and that "plugged and played"Once I have unplugged it and sent it off to be refurbed, is it a case of just plugging it back in? To Revtronic for example?
By the way the failed unit will provide a parasitic drain on the battery causing it to be flat within a few days unless you use the car on a regular basis. Unplug it (even if you don't remove it) as soon as possible.Once I have unplugged it and sent it off to be refurbed, is it a case of just plugging it back in? To Revtronic for example?
Yes this has been my Biggest issue, the flashing odometer. Will unplug and start my adventure. Fingers crossedBy the way the failed unit will provide a parasitic drain on the battery causing it to be flat within a few days unless you use the car on a regular basis. Unplug it (even if you don't remove it) as soon as possible.
ODO will continue to flash until the car can see a Blue & Me unit but drain goes away. B&M unit must be disconnected at the module under the drivers seat (RHD). Disconnection at the radio head unit does not remove the battery drain...Yes this has been my Biggest issue, the flashing odometer. Will unplug and start my adventure. Fingers crossed
Yes I have just done this, so hopefully in the short term the car will at least not die on me any more. Can’t thank you enough. Fiat garage we’re going to charge 150£ to disconnect and it took me less than 5 mins.ODO will continue to flash until the car can see a Blue & Me unit but drain goes away. B&M unit must be disconnected at the module under the drivers seat (RHD). Disconnection at the radio head unit does not remove the battery drain...
No one responded specifically to this; did you see https://www.fiatforum.com/guides/witson-android-11-head-unit-radio-install-panda-cross-4x4-2020.908/Would you replace with the third party stereo such as the Wiston from AliExpress instead?
Yes I did. Thanks. I am as yet undecided what to do tbh. I’m not attached to the BandM so am considering the AndroidNo one responded specifically to this; did you see https://www.fiatforum.com/guides/witson-android-11-head-unit-radio-install-panda-cross-4x4-2020.908/
TheNo one responded specifically to this; did you see https://www.fiatforum.com/guides/witson-android-11-head-unit-radio-install-panda-cross-4x4-2020.908/
so the odometer is still flashing despite the unplug… is that because I need to do a new proxy alignment, to let the system know that it’s not there? I thought unplugging it would solve it…?Yes I have just done this, so hopefully in the short term the car will at least not die on me any more. Can’t thank you enough. Fiat garage we’re going to charge 150£ to disconnect and it took me less than 5 mins.![]()
The
Is the odometer still flashing? Did she have to redo proxie alignment?Wifes Panda 4x4 had all the previous problems. The odo still flashed after B&M removed sent hers off to Essex Recons found on Ebay £90 ish you send it to them by post they repair it send it back to you plug and play fingers crossedits still working OK after 3 months . You need very small hands to remove and refit the unit .
No it comes back still with all the original codes inside you just plug it back in and Bobs your uncle, I was recommended these by a friend who had used them for his daughters Ford Ka unit which is the same as the Panda B&MIs the odometer still flashing? Did she have to redo proxie alignment?
Brill. Will send off todayNo it comes back still with all the original codes inside you just plug it back in and Bobs your uncle, I was recommended these by a friend who had used them for his daughters Ford Ka unit which is the same as the Panda B&M
