Technical blown head gasket or oil cooler or something else?
griffithsrichard
oh dear ....
2013 Fiat 500c
car runs well
noticed wet patch under car
oil and water mix
coolant reservoir looks like this! milky caramel
oil in engine seems ok
is it head gasket or water pump or oil cooler? or something else?
oh dear ....
2013 Fiat 500c
car runs well
oil and water mix
As this is America, I'm guessing it is the 1.4 petrol engine.
Oil and water mixed on the floor could just be two leaks landing together.
Milky caramel in coolant tank suggests head gasket. Otherwise would be cracked head or block, so let's not go there just yet.
Oil in engine ok could mean either, leak across gasket is from pressurised oil passage into coolant channels, or could be across other parts of gasket, but coolant in oil is being evaporated off when engine hot. Probably the former.
Water pump would just leak out, giving coolant puddle only.
Not sure if you've got an oil cooler, but if this is one of those coolant/oil heat exchangers usually at the oil filter, they can leak and give these symptoms. Flushing the coolant system, then removing the coolant hoses from the cooler, and joining them together for a test run might show if problem still there or gone away. Open coolant inlet and outlet at cooler might also show some oil leakage during this test run.
Head gasket usually good, unless it has overheated recently for another reason. Any history we need to consider? Total miles?
Edit: Apologies, not enough attention to the flag. Australia, not America.
