Teignjason210172
- Joined
- Apr 23, 2016
- Messages
- 4
- Points
- 1
:bang:
Hello all. I know this subject has probably been addressed countless times so I'll apologise now in advance.....
My blower is not working.......
so this is what I've done...
1. checked the fan......its working
2. I checked the switch.......its working
3. checked the plug that connects to resistor....ok.
The Resistor is new. To be honest I cant find a way to test it with my limited mechanical/electrical knowledge.
I have feed going from each wire on the plug. The way I found out was to make up a wire with a 7.5 amp fuse. with a spade I would connect to that relevant wire then the other end I would touch a earth point (door hinge bolt). The fan would work.
Is there anything else I could do to check or does everything I do point to a dodgy resistor????????????
Thank you all in advance
