After years of having little trouble with batteries on the family cars we've had more than our fair share of problems over the last couple of years or so. It started with my boy's Punto which stopped doing stop/start. Now I know that our wee FIATs are well known for this problem and many say to just ignore it and carry on. I put a DVM (voltmeter) across it and voltage read around 12.4 or so (checked several times over the course of a fortnight or so) with charging voltage showing at over 14 volts consistently. The car still cold cranked well in the mornings so we decided to just let it carry on. A couple of months later it failed to start on a cold morning, managing to go over compression on a couple of cylinders only before the dreaded clicking solenoid was heard. It started easily on my big old jump battery (but I had to drive across town to help him) and showed a good charging voltage when running. Kenny at Harrison's got us a new budget battery (mentioned on the forum somewhere) and it's been fine ever since.
Around a couple of years ago stop/start stopped working on the Ibiza just before we went on our annual road trip to Devon. The car was still starting fine - it always starts with very little cranking - so we just went off hoping it would last a bit longer. It didn't, failed one morning at sister in law's in deepest Devon countryside. I think the fact it always fires up very readily and the engine only a "tiddler" so doesn't make much demand on the battery was masking the future failure of it. Luckily I had my CTEK in the boot which allowed me to charge it enough to get going and travel to Croyde Motors where they fitted and coded in a new battery (at considerable expense though)
At sometime in that timeframe Becky's battery also failed (Becky being our 2010 Dynamic Eco Panda) but she politely notifed me she was in trouble by performing slow cranks several times before actually refusing to start so I was well warned. Got a very good bargain with my trade card on a Yuasa from Halfords. - Reported on at the time in the forum.
So, with all that in mind, I've been thinking on and off about buying a battery tester. Don't want to spend a fortune on one just for home testing though but it would be nice to be able to monitor the two loose batteries I have which I use for jump starting "family fleet" and friends vehicles. I prefer not to jump start strangers cars and even feel a bit nervous doing friends what with the possibility of damage to electronics on modern cars and the resulting bad feeling of the owner if something were to go amiss. That's why I like to use a stand alone slave rather than jumping vehicle to vehicle (Which I just don't do with modern vehicles)
Back when I worked on the shop floor we tested batteries with a heavy discharge drop tester. Basically a couple of hefty probes with great big, low resistance, shunt between them and a voltmeter which was applied to the battery terminals. The shunt controlled the resultant load but it pulled a hefty current, it got pretty hot! - Maybe 100 amps or more, probably similar to what a hefty starter motor would pull? - I see a modern version of this type of tester is available: https://www.machinemart.co.uk/p/cla...UvNyMnYc-ZVkoLlALuBoCH-sQAvD_BwE&gclsrc=aw.ds and, because I'm completely familiar with using one of these I'm very tempted to go with one. It's very affordable too!
However, there's a "new kid" on the block these days. These testers seem not to pull high current but rather send an AC pulse through the battery under test from which it calculated internal cell resistance and other "stuff" to give it's results. I'm quite attracted to this type although it's a lot more expensive. This article gives a brief description of how they work: https://trade.mechanic.com.au/news/how-electronic-battery-testers-work
There seems to be many of this type for sale on ebay and some pretty cheap options. I'm wary of the cheapest on offer but this one seems to be the most recommended and is getting some good reviews: https://www.topdon.com/products/battery-tester-bt200 so I think that's the one I'd go for if I go with this type.
I need to do more research on this type but I like the idea of them mainly because there seems very little chance of causing any electronic problems when using one to test a battery whilst still connected to the car. - I don't like disconnecting battery terminals because of the problems this can cause with memory/settings loss on modern vehicles. - If you are looking at cheaper testers of this type I think I've spotted a potential pitfall? Before performing the test these devices require to be programmed with the battery type, AGM, Wet Flooded, EFB, etc and the cranking capacity spec of the battery. They don't all, especially the tools at the cheaper end of the scale, seem to accommodate a full list of specs. for example, In America, which I'm sure is a large market for these devices, capacity is often shown as CCA - Cold Cranking Amps - The cheaper tools seem to only display this input option so here in our country you are far more likely to find the cranking amps displayed as EN (this info is on the battery label) so I think you need to buy a tool which includes this spec in it's listing. To clarify this take a look at this:
I just popped out to the cars and into the garage for my slave batteries and photo'd their labels:
Here's Becky's
You're very privileged to see such a clean thumb nail there!
Next is Twinkle's very expensive genuine SEAT replacement battery:
Notice the all important BEM code on the label which is required, and only shown on genuine VAG supplied batteries, to perform the coding of the battery to the vehicle ECU.
Then there's the old Cordoba diesel battery which I replaced barely a year before I had to scrap her:
and finally, Becky's old battery which has been subjected to a couple of "recond" cycles on the CTEK and successfully started our neighbours Renault Twingo back in the depth of the winter chill when it hadn't been started for over 6 weeks and would barely click it's solenoid on it's installed battery:
Becky's battery was being well charged by the car's alternator but after standing for a couple of days would barely turn the engine over. I wondered if it was a parasite current draw problem but I couldn't find any and the new battery turned the engine over with great enthusiasm even after she'd had to sit for a month after our Devon Gearbox debacle a week or so ago. This is the first "dud" battery which I've subjected to a full Recond procedure on the CTEK and it seems to have restored the battery to a usable condition. For how long? who knows, but it started that wee Renault with considerable enthusiasm and it didn't fire up right away either, had to cold crank for maybe 15 second I'd guess.
The point being that not one of these batteries quotes the battery cranking amps in CCA. all are in the EN rating, although the Twink's new one gives you a few options - EN, SAE and GS, none in CCA though so how do you accurately program the cheap testers? I also like that the Topdon seems to automatically compensate for temperature which might be a factor when testing in winter on a car kept outside and I think it also compensates for whether the battery is connected to the vehicle - where small permanent current drain will be going on - or off the vehicle, so open circuit. I need to research this aspect more.
So. I know there are some electronics geniuses on here, any opinions you might like to express? which type do you think I should go for? Or, am I just as well to monitor battery voltage whilst cranking an engine with the ignition disable? That option of course doesn't help with the slave batteries which is a big reason why I want one of these tools.
Here's Becky's
