I have a Mk2 Punto ELX with a battery drain (on a new battery) - and I have searched the forums here and tested for the obvious causes.
Using a multi-meter I detected a constant 250mA drain. So I checked the stereo and the boot light i.e. I removed the stereo head unit entirely and placed a digital camera in the boot to witness the boot light going out. The drain remained so I started yanking fuses. I traced it first to something attached to the F1 fuse and then traced it further to the F53 fuse in the internal fusebox i.e removing F53 removes the current drain. This fuse supports; hazard warning, indicator and dashboard. As the clock is constantly on I decided to remove the instrument panel and test it again, the drain remained so I guess it's not the dashboard!?
So any ideas? could it be the body computer (multi-timer unit)? Any positive suggestions greatly appreciated!
