General  Axle stand weight capacity
hymerhobo
Currently looking into axle stands and taking advice from Messrs Wallet and Paranoia. Trouble is, they cannot agree. So, imagine yourselves under a 4 ton motorhome with the rear wheels off and supported on a pair of new stands. What would _you_ prefer to see printed on the sides? 2, 3, 4, 6, or 12 tons??
NB: stands are commonly rated per pair, and not singly.
I assume this is a twin axle van with the weight?
That being said I'd probably want 4 tone stands or even 4 to be extra sure
Trouble is if you start going to 6-12 ton stands is the minimum height tend to be quite high so you are jacking the van up a long way to get them under
You could start by checking the maximun permissable axle loads, take the highest rated axle (probably front).
Each stand should be able to carry at least half of the axle loading.
If half of axle load approaches the stand rating, consider a higher rated stand so as to have a safety factor.
Why do you need them?
When I had my Nissan Terrano2 and was doing repairs and maintenance myself, I splurged for the highest stands I could afford. 2 ton car, I had 4 8 ton stands, and a 8 ton jack (needed to get the car high enough).
Made working on the car a whole lot easier.
Don't take risks with lifting your car.
4 tonnes is sufficient. Go over if you can afford it.
I recently had mine on axle stands.
It had what I describe as an easy wobble at first.
Not good for the axle stands or safety.
The better ones are buttressed at the base.
I decided the stand locations were not good enough.
After changing stand position at contact under van, lateral movement and sway disappeared.
Much safer!
Very important to locate the axle stands in the correct positions also.
I was working on a sloped driveway.
4 t minimum is what i would choose.
I can do almost all maintenance jobs on my 6-berth Ducato TD10 without lifting it up on stands at all. To do brakes you only need one wheel up and there's no need to get under. It's only if you are getting serious at the front end you will need stands and there's less weight at that end. 2 tons is plenty.
