thombeal
Put them on the back seat.
that's what i do. never use the boot now. even two weeks in france last month had everything on the back seat and nothing in the boot!
8" subs will offer just midbass, 10" are more punchy, 12" are the best compromise between stuff, 15" are crap if you listen to quick hard hitting bass.
You can't be so generalistic. There's a lot more to it than cone size - the box design can have a significant effect on the sound too.
yeah duno yet mate, i picked the car up today and got chatting to the sales bloke .. he sed they do a specially made sub box that slots in perfectly in the side of the boot where there are them inbuilt parts. probs do that as it wont take up so much room then.
cheers for the help though
I can. It wasnt going into depth it was just an overview of what tends to be the difference between different size subs.
Thats just the standard fiat sub and you will need to check if you have the connector there for it.
You looked in the boot to check the conector is there? Just because you have an upgraded headunit it doesnt mean you will have the connector. You say the bass and sound quality are very good and then you say you want to upgrade them This is contradicting yourself because surely if they are good then they wont need upgrading?
You buy the woofer and tweeters as one with a crossover that splits the signals properly.
You will need a headunit with pre outs if you are going to amp componants. A standard one wont have these and you would have to buy a shiit aftermarket headunit for it to be worse than a standard fiat unit.
Changing the componants is an arse ache because they are riveted onto the door so you need to drill those out and then get your new ones in. Rears are worse because you practically have to take out all the rear to get to them.
Yeah i think so. I dont see it having pre outs no standard headunits do. The only thing yours has is DAB so i dont see why it is more likely to have pre outs. Only way you can check is to pull it out and look on the back of it.
Amp will just screw to the back of the seats, wouldnt bother with the sub mine has never moved.
What how have you managed that.
Some people use Velcro all along the the face that is on the boot floor.
How have i managed what?
