so... is it possible to fit an ARB (anti-roll bar) to a seicento without one preiously installed??? just wondering cos ive heard that there alot better than a strut brace.
Make sure you get the lot, the arb, the clamps, bolts, fittings and all. The bolts that hold the clamps (which bolt onto the lower suspension arms) tend to corrode badly, so, find your car in a scrappy, a day or so before you pull it off, soak the clamps (and I mean, soak) in WD40. Failing that, ask the scrappy to put the heat spanner (acetalyne torch) on them. You'll need to replace the bolts, but that's easier than drilling out the snapped off nut and re-tapping the thread.
