General  arb advise.
General  arb advise.
raineuk
Newton Aycliffe
Hi guys is it possible for the arb to knock on the wishbone if it is too far to one side. I've done the bushes. Done the wishbone and the drop links but it sounds like metal hitting metal on the near side when going over bumps or uneven ground. I also removed the engine mount and snapped a bolt in the process. Any how that was drilled out and replaced. The mount looks and feels fine. Any advice welcome.
IIRC, there are washers welded on to the ARB either inboard or outboard of the ARB clamp, wouldn't these stop sideplay on the ARB?
Thanks for the reply.
Good point. I totally forgot about the washers but If memory serve me right arnt they a few inches away from the bushes. I think I'll have the car up on the ramps in the morning to check that one out.
