Ive got a Fiat PDF which describes the KWP2000 protocol over K line that im looking over to see if it sheds any light.
Dan
Can you please share the Fiat PDF please? I'm tring to make this obd work. I gathered few softwares, but only partial success.
Dan
Can you please share the documents you are talking about.[...]
There are Fiat technical documents floating around that explain it all.
Ive had a simple interface going with a few different fiats, using some some software called unidiag or KWP2000 test, you can get it from the authors yahoo group. Its free. http://autos.groups.yahoo.com/group/unidiag/ You can also write definition files for different cars so its pretty customisable!
Ive had it working with a 03 stilo JTD, Fiat Punto HGT W REG '00 and a '00 reg Punto sporting.
I have an 1.9JTD Stilo from 06/2002 on witch I have tried the unidiag but with no success so far. The Stilo has a different interface than the one you refered in the web link. I have an interface cable from OBD2 16 pin connector to USB connector. The soldered pins are 4, 7, 15, 16 and the K&L lines does not seem to be merged on the circuit.
In order of greatest expense:easy for you maybe. how much is the set up to just read fault codes on any jtd?
Call them - not more than £20 I'd have thought :chin:there is still no mention of italia check on the site?
and i was more referring to the price.
How do you do that ?I hope guys that you will find any solution for our JTD enginesIm try with ELM327 and a lot off diferent applications but all show whong values(I can delete/read error code normaly)... Im try trough hiperterminal and then calculate values from RAW data and is same, so we must find hardware solution and not software...
